If I only knew strange problem!
Hi @mayer,
I have this problem too, macbook pro Retina Late 2012 A1425.
Have you fixed this error yet?
Thanks.
Update (06/22/2021)
Macbook Pro Retina Late 2012 - A1425
“[06/22/21 08:46:46] Speaker: Speaker Valid Vendor ID Test (test #5) - Speaker Valid Vendor ID Test
- Verifies the speaker vendor-id is valid, if it's '?' it's not supported, if it's 0xFF there is a problem mathing id's.
[08:46:47] ERROR -- 4 [Valid Vendor ID Test Fail.] -- TEST FAILED
[06/22/21 09:38:12] Thermal Interface: Processor:Processor0 (test #4) - TIM Test 75 percent GB
- Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guardband.
[09:39:06] ERROR -- 255 [Unknown result-code 0xff] -- TEST FAILED”
Fan max speed ~8000 rpm
My Macbook has 1 screw missing as shown in the attachment, and 1 speaker on the left side of the picture is damaged; My Macbook fan runs max 8000rpm; I don't know if it's because of these 2 errors?
Esta é uma boa pergunta?
3 comentários
How about giving us a bit more on what your problem is
If you can let's run the onboard diagnostics to see what errors pop with it. Restart your system and press the D key to enter
Reference: Mac startup key combinations
If that fails to offer anything how about installing this great thermal monitoring app TG Pro take a snapshot of the main window (make sure you get all of the sensors as some are hidden at the bottom of the window)
por Dan
@danj This is the question he is referencing: Thermal Interface -Video Controller ASD Error Which is on a 2007 iMac. Is your Crystal Ball Broken?
por mayer
@mayer - Ha! It sometimes is a bit foggy though ;-}
But the ASD error doesn't apply in this series no AMD or NVIDEA GPU in the 13" MacBook Pro retina models (Intel HD Graphics 4000 engine).
por Dan
