Ir para o conteúdo principal
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 Perguntas Visualizar todos
Removing adhesive from digitiser
Hi,
Could anyone tell me the best way to remove the old adhesive strips and residue from digitiser so it is ready for re attachment?
Should I heat on front to remove strips more easily? Should/can I use isopropyl on inside without damaging?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I don’t know, but I would use heat to remove the solid pieces, then Isopropyl 90% or better to remove the residue. BUT if the battery is still connected, do not get it on any circuitry
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chris Reader será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 35
