Ir para o conteúdo principal
Repair guides for displays (or monitors) for computers or other devices with video output.
power supply needs replacement
the power supply burned out on my Dell u2211h ultrasharp 21.5 monitor. its intermal to the monitor. I know I can replace the power supply but cant figure out how to take appart. already removed the 6 screws. there is a symbol that looks like a lock, any help would be appreciated.
thanks
Esta é uma boa pergunta?
Pontuação 2
1 comentário
My monitor just go off but the power light is on when the PC go standby the light change to orange color when wake the PC then it on green normal but no picture you can the light flash a little bit second with low bright ….I am confused now the monitor name is viewsonic …VA902…19 inches
por
Adicionar um comentário
2 respostas
Solução escolhida
Here is a link for downloading the service manual for your monitor. Good luck.
http://support.dell.com/support/edocs/MO...
Esta resposta foi útil?
Pontuação 2
after you have taken the screws out, just prey the joint frames that holds the screen panel with a flat screw driver..that should enable you to open the monitor. good luck
Pontuação 0
Adicionar a sua resposta
cesare será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 858
