Ir para o conteúdo principal
Repair guides and support for cash registers.
"E" appears at the corner of screen and not able to punch any numbers
"E" appears at the corner of screen and not able to punch any numbers and beeps until I hit PLU/SUB button an noise goes away. This is happening in Sharp ER-A320 cash register.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I do not know this item, but the easy fix is a power reset. Unplug for 30 sec the replug power. If that doesn’t do it, it may be indicating a drawer jam. other than that, it would be a more serious internal problem.
Esta resposta foi útil?
Pontuação 0
2 comentários:
To make sure it is not a door jam look on the bottom of the register for a lever (small usually metal) and move it to open the drawer. It you move the lever and it does not open it is jammed.
por
Door is not jammed as I was able to open from the lever on the bottom of the register. I tried to plugging back with JOURNAL and PAPER FEED keys pressed. No luck yet.
por
Adicionar a sua resposta
Thomas Peters será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 23
Ao todo: 834
