Ir para o conteúdo principal
Released in 2008. Will have model number KDL-52W4100 the bottom right corner on the front.
2 Perguntas Visualizar todos
intermittent horizontal lines on bottom quarter of screen
Sony KDL55W65: Getting intermittent horizontal lines on bottom quarter of screen. 2 seconds of lines, then 2 seconds of normal. Maybe a loose connection? Repairable?
This is a Sony KDL55W65. I chose Sony KDL-52W4100 because it was the closest option.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
loose connection possible. But a loose connection would not repeat an on/off cycle 2 on/ 2 off………..
each section of the screen is driven separately. It sounds like the circuitry for that section has a problem.
It is probably fixable by replacing the driver board for that section (though the board may include all sections). You need to look at whether it is worth the part and time/effort. The part might be used (cheaper) and the rest of the TV my have a smoldering problem (bad capacitors). There is no warranty on anything. New TV will have some kind of warranty.
There may be a Sony specific community forum that will have the exact problem and more info.
Esta resposta foi útil?
Pontuação 1
1 dos comentários:
This is helpful - thank you very much, Bill
por
Adicionar a sua resposta
Phil será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 120
