Ir para o conteúdo principal
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Perguntas Visualizar todos
Screen does not hold up
Hello
My MBP’s screen does not stay up. The screen has been changed, but quite rapidly it did not stay up but flips down again. It’s annoying and will one day be damaged. I opened it, looked to the hinges, that seem OK. Do you have a trick to make them tight /stiff ? Ideally without changing any electronic parts, that are expensive and complicated to modify.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Apple had a recall on the display assemblies of this series which I think has now ended. What happened is the press-fit pin into the aluminum lid failed to get secured so the pin which needs to be anchored in the lid is floating so the clutch spring which grabs it to gain the needed friction to hold the lid up is not able to do that.
Now that we understand the problem what is the solution? At this point you could see if Apple will still honor their recall on the defective lid assembly (was a limited recall). Otherwise its time to get a new display assembly as there is no means to fix this. Trust me I’ve tried!
Another approach is to get your butterfly keyboard fixed as its still under warranty for that (assuming you can argue you have a bad key or two) as Apple will then replace the uppercase to fix that and the QC folks will reject the repair as you also have the display issue and they will then fix that as well (Apple has a zero defect rule so any other problem found is also fixed as well under the first repair).
I know this is somewhat convoluted, fixing a different problem to fix this. This tends to be more effective way.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
info será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 20
