Ir para o conteúdo principal
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
Mouse pointer begins to lag while using the computer often
I have a Mac Pro (mid 2012) Xeon Westmere 6 core dual processor with 64 GB of RAM and ATI GTX 680 GPU with macOS Mojave 10.14
The problem is that the mouse pointer begins to lag while using the computer often
The important things that I have also using an Avid HDX card in my Mac Pro
Please can you provide some help?
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
What is your boot drive and how much free space?
por
Is this a wireless mouse? If either please try changing mice to rule the subjects down.
por
kingston 256 gb ssd 173.5 gb available
por
@atomintheworld i have magic mouse also i tried wired mice
por
Adicionar um comentário
1 resposta
I‘m sure your system is running out of resources! Audio production can be quite taxing on your system. Your SSD is on small side for larger projects.
I would review your drive setup, making sure your boot drive SSD (hopefully larger - 1 TB) is using a SATA III (6.0 Gb/s) port board (and is a SATA III drive) and Avid HDX board directly from the North Bridge chip PCIe slots not via the PCIe switch slots. This SSD needs hold your running OS, primary Apps and a least 1/3 unused for your OS and App’s to use for virtual RAM, caching & scratch space. Only your current work should be on this drive.
Use the South Bridge chips SATA ports for your loose apps you rarely use, and anything else.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
sneham sound city será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 145
