Ir para o conteúdo principal
Logo, spinning wheel then blank illuminated screen
I’m guessing something serious and basic has happened. I haven’t tried using the G5 for a while, don’t want to throw it away. Would it be possible to adapt it to use the screen as a monitor?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
A white screen is indicative of a failed hard drive. To test boot up from an external drive or the original installation disk. Insert the disk, hit the power button, push the disk all the way in and hold down the “c” key.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks. Do you know whether I would be able to use the screen as an extra monitor rather than actually fixing the device to run as a computer again?
por
Adicionar a sua resposta
Janet King será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 63
