Why is my phone not charging?
My samsung a31 phone not charging
Esta é uma boa pergunta?
Well, mobile is not charging is mainly happen because of the bad charger. Now the first thing you should do is to change the charge and then if it is not working then the charging jack of your mobile phone can be the cause replace it from a mobile repairer Your mobile will get starting charge.
Esta resposta foi útil?
الهاتف دائما يعيد التشغيل والشحن يسقط بسرعة
Try to reset it if it didnt work change the battery
Well you can try the following it might help you out:
لماذا هاتفي دائما ما يقفل ويعاد تشغيله والشحن من ممتلئ الي شحن صفر
Some times my mobile not charging, after restart the phone it starts charging
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 16
Ao todo: 1,599
2 comentários
Solw charging
por Ashebir Makunnt
3 month ago in my phone no charge
=== Update (08/09/23) ===
No no charge is there in my phone
My phone is dead thanks
por Adinath Panchal
