Ir para o conteúdo principal
A 10 speed mixer made by KitchenAid in 2006.
27 Perguntas Visualizar todos
Kitchenaid 600 making a spinning sound, but not actually spinning
When I turn the gears on, sometimes nothing happens, but if I turn it up high and jiggle the gear, the engine will make a sound, but nothing that is visible will spin. I’ve taken it apart, but now don’t know what to do! Ha! I’m eager to fix it but I’m a noob.
Any thoughts would be much appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like the motor is working fine, perhaps while you have it apart follow the mechanical connections up to the source of the problem? Might help to stick in one of the mixer things and spin it manually to see where it isn’t connecting.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Elizabeth R Tolmach será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 39
