Ir para o conteúdo principal
Line of business laptops originally sold by IBM and then purchased by Lenovo in 2005. Older models (Pre-XX50) have a WiFi whitelist, so wireless card replacement is not as easy as buying a bulk generic card online.
577 Perguntas Visualizar todos
Thinkpad 2 Lenovo Red blinking light and my computer will not start
I have a Red blinking light on my Laptop and my computer will not start. How long should I keep it charging. The red blinking light has continued for a couple of days and won’t start? It's a Thinkpad 2 Lenovo What does that mean? Should I continue charging. I want to also assure that I'm not wiped out on my computer. How may I assess the programs if repair is needed?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
wait to light turn white then turn on the laptop
Esta resposta foi útil?
Pontuação 1
If the LT is plugged in and charging, it should start regardless of the charge level of the battery.
Unplug and remove battery. Press and hold power button for 5 sec. Plug in charger and see if it turns on. If so, turn off, insert battery and try again. If it again does not go on, It is possible the battery is pulling too much current. Replace battery.
If it does the same thing with only the charger, then there is an internal problem and needs serious help.
Note that this kind of problem can be economically prohibitive to repair.
You can access your data by removing the memory device (HDD or SSD), installing in an external enclosure and plugging that into another computer. Note, You may need to get more advice on accessing your data especially if you have encrypted it. It will likely object to your access in another computer and you will have to take ownership of the files in the new computer.
You don’t by change (or smart planning) have your data backed up anyplace, do you?
Pontuação 0
Adicionar a sua resposta
martha williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 116
Últimos 30 dias: 650
Duração total: 16,784
