Ir para o conteúdo principal
Optical drive will not open
I followed the repair guide for this issue, though the optical drive still will not open when the button is pushed. I can hear it trying and was able to get it to work once with the help of a spudger. Is there a common issue that I may be overlooking? I cleaned the rails, as well as the rubber belt that controls the movement, but nothing seems to be working.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Rubber belt get old and take a set especially if not used for a while. Cleaning doesn't help unless they are still soft.
Start by replacing the belt. If that doesn't work, there may be cracked plastic gears slipping on their shaft. Plastic does that when it gets old.
Esta resposta foi útil?
Pontuação 1
I have this problem as well what I did was to hold down the button.
Pontuação 0
Adicionar a sua resposta
TYLER GOODWIN será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 95
