Vertical line shadow appeared in the middle. What to do?
I'm about to panic. seeing the line vertical shadow on my Samsung curve TV.
What should I do?
Should.turn it off not use it . It might get worsed?
Esta é uma boa pergunta?
What should I do?
Hey Kaisiquian,
Are the lines permanent or are they moving?
If they are moving check the input connection (display port, HDMI, PC) Maybe try removing the connection and re-establish it.
Do the lines appear when the TV menu is up?
There should be a self diagnostic test built into the TV that you could also look into. It should have a ‘Picture Test’
If the lines are permanent, you may want to call a support number, unless you want to physically change your own huge screen.
Hope this helps.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 38
Duração total: 1,217
