Ir para o conteúdo principal
The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
Why is my phone the only one with this problem?
So about 3 days ago my phones wifi was fine. Now however I can’t use wifi. i’ve tried restarting my phone. Disconnecting and reconnecting, resetting router. Nothing seems to work. It there any reason why this is happening to only my phone?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You said you restarted your phone. Did you try a complete hard reboot by holding down your phone's power button and selecting “Restart" from the popup menu?
If that doesn't work, try resetting your phone's network settings. Go to the Settings app and type “Reset Wi-Fi, mobile, and Bluetooth” in the Search bar. Select the option and follow the prompts.
You will be asked to re-select your Wi-Fi network to connect to it .
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tyrell-Chan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 105
