Why is it slow to boot up
very slow to boot up and runs slow after installing big sur
Esta é uma boa pergunta?
If your computer still has a standard hard drive or fusion drive, I’ve noticed quite a lot of them running very bad on BigSur. I would suggest either replacing the hard drive of the fusion drive with a 2.5 inch SSD or going back to macOS Catalina.
Esta resposta foi útil?
Where is the hard physically located? I'm having a very hard time disconnecting the cables from the display or the chassis. I have purchased a SSD that I will try to install if I can get there.
@ldonj - follow this guide Substituição do disco rígido do iMac Intel 27" com tela Retina 5K 2019
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 288
1 comentário
Reboot your system and press the D key to enter into diagnostics. Did you get any errors?
Reference: Mac startup key combinations
por Dan
