Ir para o conteúdo principal
My battery corroded the main connectors. Can it be repaired?
While in docking port, ERR 3 the battery corroded the units main charge connectors. I tried reaching it with q-tip with vinegar, but it qasnt enough so it will require a full breakdown. Do you repair?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
almost anything is repairable. 1st, can you get the parts required: 2nd can you get the tools required: 3rd can you find directions needed:
For battery contacts, vinegar and sandpaper work unless the contacts are eaten away.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Robin Harper será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 193
