Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Why won’t my iPhone charge after replacing battery and charging port?
My iPhone 5s showed no signs of life until I put in a new battery and it turned on. I tried plugging it in to the charging port but it wouldn’t charge, I replaced the port but it was after the battery had died so it is on the red battery screen. I tried plugging it in and leaving it for an hour but it still wouldn’t charge. The blank screen only shows a blinking red battery and a charger at the bottom even when it is plugged in. I have gone back a few times to make sure I have not broken anything and everything looks fine. The only other thing I think it could be is the motherboard which I have read could cause charging issues but would appreciate any help to figure out my issue.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Have you tried changing cables? It may seem like a simple solution but many times I’ve changed entire charging ports in phones only to realise I had a faulty cable from the start. If the phone was working fine with the new battery and you’re confident the charging port isn’t the problem, the only other thing I could think of would be the cable. Make sure you’re using a genuine Apple cable if possible, and plug it in using a genuine Apple wall brick for iPhones.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have already tried using two of my friends chargers and neither of them charged my device.
por
Adicionar a sua resposta
Frank Jr Vasquez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 74
