Ir para o conteúdo principal
Boots Up with chime, blank screen nothing happens
My MBP suddenly doesn't turn on properly. The computer turns on, but to a blank screen. I hear the startup chime and the HD whirring. Also, after a few seconds the keyboard lights up.
I took out the HD for testing, and everything looks fine.
Any ideas?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Could be a GPU failure. The MBPs A1226 and A1260 use the problematic NVIDIA GeForce 8600M GT graphic card. If you don't have video on an external monitor contact Apple cause your computer could be repaired free of charge via the Apple special Nvidia replacement program.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Or if you have a spare computer you can use that as an external display.
por
Curious ! How would you do that ?
por
The easiest way is with ScreenRecycler but I'm pretty sure that won't work with a computer not turning on properly, so there are a bunch of ways to just connect to the LCD,etc. I've never tried or need to try any of them, however if you look at online forums you can find many ways, you need some adapters I think though.
por
Try connecting to an external display, could just be a bad LCD.
Pontuação 0
Adicionar a sua resposta
Enon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 4,688
