Upgrade ssd worth it? What size?
I have a 1 Tb Fusion. Upgrade?
Is the screen that hard to separate without cracking?
Esta é uma boa pergunta?
You will notice a pretty big difference in performance getting an SSD in an older iMac.
Using a tool like the one that’s including in this kit makes it very easy. If your iMac is cold to the touch before starting area warm the edges up a bit with a heat gun.
https://australia.ifixit.com/products/im...
Make sure you back up your data to time Machine before starting as restoring your iMac with a split fusion drive can be a pain.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 41
