a10s will not turn on
samsung a10s will not turn on and will not changer too
Esta é uma boa pergunta?
Remove the back and disconnect the battery reconnect the battery and plug the charger in.
Esta resposta foi útil?
hello as i owner of this phone i have dealt with the same problem if i press the power button nothing happens i can still unlocked with my fingerprints it will unlock. If your phone is power off and you want to turn it on get your laptop,pc,mac and press the volume up and down button and plug it in the pc when it turns on press the volume down button it will restart and herre you are fixed i hope i have helped you and thank you and thi problem is caused by watter getting in the power button it happens
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 1,492
3 comentários
Hello,
Did anything happen to cause the error?
por Adam Gari
What was happening before it did this? Did it get hot? Make any noise? This post is not descriptive at all.
por Duck
my phone will not turn on with the on button
por kelli amedu
