Ir para o conteúdo principal
The JVC KW-V820BT device is a 6.8 inch car stereo receiver designed to be installed into the dashboard of a vehicle. The device features a touchscreen display and accommodates sound from a variety of sources. The device will interface with multiple phones simultaneously and allow users to interface with some apps.
Pioneer AVH-P6300BT needs a touch panel replacement
Are there any guides on how to replace a touch panel for my dad’s old pioneer AVH-P6300BT? i got quoted $1000 to replace the touch panel when my dad had to slam on the brakes and my dog slammed into the screen. the tilt mechanism is damaged but i dont care about that, it wont accept touch input which i do care about, but everything else works, like the LCD shows an image clearly, aux works, im sure bluetooth works, and we had no issues with it other than the touch panel being cracked and not working. would there be any underlying issues that cause more damage than a broken touch panel? btw, it is a resistive touchscreen, and the clear plastic in front is fine, the plexiglass (i assume) is shattered behind the clear plastic, and there are no damaged pixels or anything.
(i picked the jvc unit as my device because ifixit doesnt appear to have a “my device isn’t listed” option)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Some radio models have a separate touch-panel digitizer which can be replaced while keeping the original LCD screen. Most don't, however, so you have to replace the entire screen assembly as one expensive piece. There are shops that specialize in radio screen repair, so hunt around online and find someone is who is familiar with this series of Pioneer radios. You'll likely have to send it somewhere for repairs. $1000 is too high, even for a unified screen assembly. Keep looking for a specialty repair shop that knows about these types of radios. But also be prepared for sticker shock because there's lots of labor involved in replacing the screen.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ChazIsBuns será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 262
