Ir para o conteúdo principal
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Perguntas Visualizar todos
Not turning on HELP
Hey guys, girls, lgbtq+, friends I bought a surface pro 4 that was broken. According to the owner it ran out of battery and then wouldn’t turn on after that. I checked it and I heard that there is a 0 ohm resistor under the cpu that is most common to blow. I know how to solder but I dont know how to microsolder. Is there a solution and how would I measure the resistor if its broken. I have a multi meter but I dont know how to measure it for the surface pro 4. Please help me looking forward to your reply.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
if youre just checking resistance check out this handy guide.
https://www.allaboutcircuits.com/textboo....
edit: youll need to know the resitance of said resistor!
good luck
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hey so I heard I need to jump if do you got tips to desolder something so small and will a hair dryer work I got a soldering iron but it seens massive compared to the little resistor
por
Adicionar a sua resposta
kevin leng será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 81
