Ir para o conteúdo principal
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
second SATA drive
I saw this post just after asking the same question !
But if the "Dual Hard Drive Kit" provided by iFixit is capable of plugging a second SATA drive with a specific cable, could not the same cable (or a close cousin) be used to connect a DVD drive ?
And how bad is the angling needed to slide in the logic board when the optical drive bracket is present ? Does it brake anything or is it manageable ?
Likely, the best solution would be for iFixit to provide an "Optical Drive Upgrade Kit", as they did with their "Dual Hard Drive Kit"...
Anybody listening here ? ;-)
Esta é uma boa pergunta?
Pontuação 1
1 comentário
You are asking your question as an answer to another person's question - that already has an accepted answer. Please ask your own question so that your problem may be properly addressed.
Originally posted here:
Can a 2011 Mac Mini fit in a 2010 case?
por
Adicionar um comentário
1 resposta
Solução escolhida
There's room for a hard drive but not an optical drive.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
geeji será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,912
