Ir para o conteúdo principal
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
48 Perguntas Visualizar todos
Is it Possible to repair Transcend Pendrive?
4 GB,from last 2days ..when i put it on the PC,it is telling me that it not recognized .
i even have information on it but the only option it is giving me is FORMAT .
when i click on it ,it saids can not be FORMAT.
Is there any way to get my information back and do something and the pendrive will start working again?
i will be glad and very happy to hear your suggestions.
thanks
in cmd promt when I press h:
itsays Incorrect function
Esta é uma boa pergunta?
Pontuação 11
3 comentários
Have you tried this format command after you are at the command prompt format <your drive letter> /q /fs:fat32
I just tried to format an unusable USB pendrive that I had (due to removing it without first disabling it I suppose) I used the program from here http://en.kioskea.net/download/download-... that I had from previously making a USB drive bootable, and it worked. So give it a try and see if it works for you. http://www.linuxjournal.com/article/8366 has more information about how to access a corrupted USB drive with Linux.
por
Transcend have their own formatting tool you can download it using the serial number on you Pendrive, try it, hopefully it will resolve your issue
por
Download transcend recover software from transcend website... try to format by software. May be it will help.
por
Adicionar um comentário
5 respostas
Solução escolhida
You can try using something more powerful than <Put int your OS> stock format tool. I would recommend GParted - you will be able to see if there are partitions, verify, delete, reformat, etc. If that will not help, most likely you will end up throwing that usb away.
Esta resposta foi útil?
Pontuação 3
1 comentário:
This might also work to see if you can get any information/files of the drive. Of course only if they have not yet been overwritten.
por
Today when I try to use my pendrive it was not working and it had a very important data in it. Then I called up my brother and i told him that my pendrive is not working , he gave me the link http://softwaretricks.in/forums/index.ph... where I was able to fix my pendrive issue I hope it works for you too.
Pontuação 0
I have a 16 GB transend pendrive.now it is not working.some time detect.I hope anyone of you will help me
Pontuação 0
Format failed (0x1901). Please send your device to the nearest transcend strore or contact
Pontuação 0
Have a look at this link http://www.repaircrashed.com/pen-drive/ it will show you step by step method to fix pen drive is not recognizing error.
Pontuação 0
Adicionar a sua resposta
karty será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 13,579
