Ir para o conteúdo principal
Battery or Dock Connection!
I have an older itouch first gen, when I charge it it doesn't hold the charge, can you tell me if this is more likely a battery or dock connection issue? It does take extra effort to show when it is connected to charge... seems looser than in the past
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Being a first generation it is likely a battery. You can visually inspect the dock connector to see if any pins are missing, bent, or a buildup of debris. However, if the dock was faulty you may get no response when plugging the device in. The batteries are not made to last forever (planned failure).
This repair requires solder, but is the easiest of the touch batteries to install.
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
matt119 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 379
