Can’t turn on,
Can’t turn on, when plugged to charge it turn on immediately by self but can’t control, can’t connect . When unplugged it immediately turn off by itself also
Do you know what is issue?
Esta é uma boa pergunta?
I have the same problem. What's the solution?
Esta resposta foi útil?
its in demo mode?, if i remember press and hold the Power button and play button simultaneously until it turns off, then you can turn it on and do a reset by pressing play and volume up button until it turns off, then you're good to go.
That didn’t work for me now what?
After a few tries, I was able to fix it with this tip! Thank you 👍🏻
Any progress on that problem? I'm having the same problem now.
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 2,447
