Ir para o conteúdo principal
Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
149 Perguntas Visualizar todos
iPhone 11 pro keeps turning off and on again every 3 minutes
Hi,
I have an iPhone 11 pro that keeps turning off every few minutes but then it turns back on again and it keeps doing this.
Do you think something such as a new battery will fix this issue or is it something more complex than this?
Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
A new battery might fix it, if not it will be your charging dock assembly. If you are going to replace the dock assembly make sure it is a genuine one pulled from another board as some aftermarket ones have faulty or no sensors which makes the phone restart every three or so minutes.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Eisah Sharif será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 728
