Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
PowerA controller not pairing
Hi, I had to send my joycons to get fixed (drift much) and I had a PowerA enhanced wireless controller connected and paired to the switch so I kept on using it and had no problem even without the joycons. Until I decided to try and connect it to my PC and to do so I unpaired from the switch, now I'm trying to connect back to the switch and it does not pair! Has anyone seen this before? Do I need the joycons to pair it back? I'm using the touch controls in the change grip order to pair it with no luck, I already followed the steps correctly. What am I doing wrong?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Trying the “find controllers” feature could work to connect them, or maybe if the controller has a sync button try that. I don’t know if you have the power-A controller that uses batteries or has the usb-c port, but if it can run with a wire try that maybe. I hope that helps somewhat
Esta resposta foi útil?
Pontuação 0
2 comentários:
I have the one with batteries, no wire connection possible. I tried the sync button and the lights in controller indicate it is in syncing mode but it never comes up in the switch in the change order/grip screen! Thanks for the answer though ?
por
I guess find controllers is your best bet, since you didn't mention that you tried that. If the switch remembers a controller, and you hold on it in the menu, as long as the controller is nearby and has battery power it is forced to connect. I had this same issue on my pro controller a while back
por
Adicionar a sua resposta
Felipe Akira será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 1,952
