Ir para o conteúdo principal
iPhone 11 Screen Backplate Problem, Fitting
Hi guys, i know this is kinda dumb but i think because i try to pull the screen out while forgetting to remove the bottom crews, so now the backplate is having a problem.
I tried to press the backplate back to the screen but it won’t stick , even after closing the screen and press tightly to the housing, it still does not fit fully 100%, maybe around 80% . Does anyone has any idea how to fix this ? Maybe glue or anything ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Properly attaching the frame back onto the glass requires some kind of machine to apply the structural and watertight adhesive, which is difficult. You need to pull the frame completely off then reapply.
Maybe just replace the screen.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
min lai será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 52
