Ir para o conteúdo principal
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
iPad Home Button not working after Digitizer Replacement
I replaced the digitizer specifically because I accidentally broke the home button connector ribbon. I have to use the one I have (the new one I mean) or buy another. When I connect the digitizer and LCD panel, the home button does not work. I have not fully assembled the iPad yet, as I wanted to check if it worked. Do I have to fully assemble to get the button to work? and if not then can anyone see my problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
That looks like an iPad Air home button, which carries a different protocol and is not compatible with iPad 5.
Either that or the home button is faulty.
Esta resposta foi útil?
Pontuação 1
2 comentários:
That’s actually a really helpful input, when I bought it it was labeled as a digitizer for iPad 5 or iPad Air. So does this mean that it just really isn’t the right home button?
por
@Nathan Mayo That explains it, you got the wrong home button (iPad Air)
por
Adicionar a sua resposta
Nathan Mayo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 109
