Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
MacBook backlight slightly flickering
I closed the lid on my MacBook and after I woke if from sleep the backlight slightly flickers, its a consistent flicker and very slight but also very noticeable. It only happens when there are light colors on the screen (which makes sense if its a backlight issue). When i plugged it in the flicker went away for a few seconds but then it came back. I have already tried resetting smc and pvram/nvram to no avail
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Given the ago your system let's first check the battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
You might want to replace the blacklight pad
Esta resposta foi útil?
Pontuação 0
3 comentários:
Take a look at this MacBook Pro Retina Display Teardown Jump down to Step 13 where you can see the discreet LED's.
These displays are not really serviceable.
por
Is this about the keyboard or the display, because I thought you were talking about the keyboard
por
@jellybean2_0 - "It only happens when there are light colors on the screen" I think clarifies its the display thats in question.
I wanted to check the battery as a failing battery can cause voltage stability issues. Which in turn would affect the backlight.
por
Adicionar a sua resposta
Shaan Patel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 116
