Ir para o conteúdo principal
The Sony Cyber-shot DSC-HX80 is one of the world's smallest compact digital camera with a 30x zoom lens. It was released in 2016 by electronics company Sony.
5 Perguntas Visualizar todos
What do you do when you have accidentally torn a tiny wire ribbon?
Along with loosening all of the other walls, I removed the left side panel (under the viewfinder) and a little yellow wire ribbon came out with it. I can’t even find the other end of the tear inside the camera. The tear occurs just after a right-angle bend in the cable. Also, I can’t determine how to detach the main golden wire ribbon from the lens (I’m attempting a lens replacement), despite removing several screws on a large, circular silver plate. The walls are not pulling apart very far in order to give me proper access. I don’t want to force it to the point of breaking something else.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
take a couple pictures, that would help point you in the right direction with this tear down. if its a ribbon cable that is actually ripped.
this site seems to have a couple ribbon cables as a replacement.
https://sony.encompass.com/item/10344184...
https://sony.encompass.com/item/10333301...
https://sony.encompass.com/item/10344257...
https://sony.encompass.com/item/10318414...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Eric Torres será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 194
