Ir para o conteúdo principal
while trying to start realized the cam is not moving just swings
hi guys i have a citi 1.4i mp9 car just died when driving i than checked the the plugs seems fine i checked the plug wires seems fine i than open the cam timing cover to check to check if the cam is moving while trying to start realized the cam is not moving just swings no power what else could i check
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like you have a bad timing belt or chain. Unless you are a mechanically inclined person I would take it to a shop and have it checked. If it broke while you were driving and it's an interference engine you will have to have the head pulled off and new valves replaced with any bent ones and a new belt or chain and tensioner.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jermaine Edwards será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 19
