Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Perguntas Visualizar todos
MacBook keyboard repair after a liquid spill?
Ok, so I had a liquid spill and luckily worked fast enough that the only damage is a couple of keys misbehaving. This is the first computer I've had with the keys enclosed by the shell itself. First, how do I get the keys off? Second, will I expect this to be as easy as cleaning up with a little alcohol with the power off?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
4 respostas
Pergunta mais útil
This is the most protected mac I've ever seen against spillage. According to the liquid you may be able to clean it right up. I've changed out the keyboard and it was simple and fast. What did you spill and how much? For the keys, use a small flat head screw driver to gently lift up the key from the backside until you can get a fingernail under it and lift till it pops off. Carefully examine how the scissor plastic key retainer is positioned . Look at the bottom of the key to see how it snaps into it. Lift the sides of the retainer on both right and left side to observe how it works. Take the retainer out and put it back in to understand it. The major problem is getting those little bitty plastic pins into the holes. I use a plastic toothpick to lift and separate inserted from the right. You're now a mac keyboard tech, junior grade. I use iisopropyl alcohol on a Q-tip to clean. Do not use rubbing alcohol as it contains to much water.
Esta resposta foi útil?
Pontuação 1
I need to replace my A1342 keyboard. Does anyone know how to do this or know where I can get a guild...
Pontuação 0
Got a MacBook a1342 and a small amount of water was spilled on the keyboard and the full keyboard has completely stopped working can anyone help me out here ?
Pontuação 0
On this model you're kind of stuck replacing the entire top case. It should be $40-$75 based on availability at the time. Check the motherboard for signs of liwuid damage or corrosion while inside.
Pontuação 0
Adicionar a sua resposta
Ritch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 8
Duração total: 31,208
