Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
it is cranking but want start
I bought a 2004NISSAN ALTIMA THAT WAS FIRING UP ON THE DIME NO PROBLEM BUT I SWAP IT INTO ANOTHER BODY WHICH IS A 2006 NISSAN ALTIMA BODY NOW IT IS CRANKING BUT WANT START BUT WHEN THEY POOR GAS OR STARTER FLUID IT CRANKS UP AND RUN FINE BUT AFTER TURNING IT OFF SAME THING TURNING OVER
Esta é uma boa pergunta?
Pontuação 0
1 comentário
So it will only turn over if you're actively putting fuel through the engine?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like its not getting fuel. Make sure that the fuel injectors are working and the fuel pump. If the fuel pump isn’t working, your engine will never start.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Pamela será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 89
