My MacBook ays it is charging even though I am not connected to power
My MacBook Air 2018 13” is saying that it is charging, even though I am not connected to any power. Could someone please help me fix this.
Esta é uma boa pergunta?
I solved the problem with apple support! For anyone else having this issue, you need to reset the SMC. Shut down you Mac and then hold left control and option and right shift down for 7 seconds, then hold down the power button while still holding down the other keys for another 7 seconds. (If your mac turned on while holding ctrl, option shift it will turn off). Once you have done both steps, release all the buttons and press the power button once to turn your laptop back on. This should solve the issue!
Esta resposta foi útil?
So you must be using Tesla’s magic wireless charging solution he showed off back in the ‘20’s!
Sadly, this is not good ;-{ Your logic boards charging logic is damaged. You’ll need to bring it into someone with the deeper skills to replace the damaged chip or just replace the logic board.
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 39
