Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Screen backlight only half working
Over time my MacBook has been developing an issue, at first when I pressed the bottom area of the screen bezel it starts doing something I don’t really know how to describe, so I attached a photo, and the screen is noticeably dimmer. Currently I don’t have to do anything for it to happen, and even worse, sometimes it flickers, however the backlight never fully turns off. I tried running the laptop with the bottom off and pushing the display cable, but it didn’t do anything, so I’m assuming it’s something inside the display.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You’ll need to do a bit more digging to isolate out what’s needs fixing.
Follow this guide MacBook Pro 13" Unibody Late 2011 Display Replacement doing the first steps to disconnect the battery, then jump down to Step 14 carefully disconnecting the LVDS cable and inspect it and the logic board connector for corrosion
The other end of the cable is a bit harder to get to as that too can face the same problem. At which point you would likely need a new display to fix it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
iSzymon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 165
