Ir para o conteúdo principal
O iPad mini de primeira geração de 7,9 polegadas da Apple, lançado em 2012, com 16, 32 ou 64 GB de armazenamento e processador A5.
Ipad Mini Won't Respond.
The Mini Ipad does not respond at all. It worked perfectly until the home button was unresponsive. Then, the home screen became like a “glitch” when I turned it back on after I turned it off to do work outside. I can’t press the pass code or anything to get in. Every time I turned on the home screen, it then “glitches” and fades to black. Somehow, the home button was working again but only for the power reset. I then hold both the power buttons to reset it but it then made it worse. I turned it back on, the Apple Logo appears, and then it fades away like a “glitch” to a black screen. I even tried doing it with a charger on as well.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
What happens when you do a soft reset (hold home button & power simultaneously)? If that doesn’t reset it, can you connect to a Mac & restore it?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Blue Dude [G] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 195
