Ir para o conteúdo principal
Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
468 Perguntas Visualizar todos
Cannot be paid by card. NFC does not work
hello please, i have a problem with iphone xr.  nfc didn't work after the housing change.  so I thought the coil would be damaged, I replaced the coil with a new one and it still doesn't work.  is the nfc antenna connected to the bottom antenna?  because I'm partially damaged here.  I'm running out of ideas ...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The NFC antenna is connected to the TOP antenna, no use fixating on the bottom side.
Esta resposta foi útil?
Pontuação 1
2 comentários:
which antenna affects the functionality of nfc? there are about three antennas in the phone.
por
There are more than 3.
There is a flex cable around the right side of the rear camera. If that one didn’t break, the case itself is the problem.
por
Adicionar a sua resposta
hipisak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 179
