Ir para o conteúdo principal
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
375 Perguntas Visualizar todos
Pushed in speaker grill, worth opening and replacing?
Hi all,
I have the iPhone XS MAX and while I was cleaning one of the left side speaker grills/vents I noticed that the mesh was pushed in quite a bit. I am wondering if it is worth me opening up the device and replacing the mesh? I have some experience opening up late model iPhones such as the 11. I would replace the waterproof adhesive around the screen but which would reduce the waterproofing more, opening up the device or leaving the speaker grill as is? Is the waterproofing damaged anyway?
any advice is appreciated
Many thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Quinn:
Replacing the speaker mesh may help with the water resistance, but if you do not need the waterproofing then maybe not.
Happy Fixing!
-Javen
@tacofixes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Quinn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 250
