Ir para o conteúdo principal
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Perguntas Visualizar todos
whats wrong with my logic board
I spilt tea on my laptop, and it wasn’t working or charging. I looked at the logic board, and although I messed up my camera wire, is anything else broken? Is there a way for me to use my laptop with a broken camera, (I have a new laptop coming but want to make sure I transfer important files/information)
Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I dont know exactly Im just wondering is the fan unplugged at all? is it loose? or is anything loose that you can see because I dont see anything that could be wrong be sides the loose or unplugged fan if its not any of those things the logicboard may be fried
por
Adicionar um comentário
1 resposta
Ouch!! This is in very rough shape. This logic board will require a lot of work to patch up. This will require someone with very deep micro-soldering skills as you ripped up many of the copy traces besides the iSight camera connector. I think replacing the logic board would be the cheaper solution MacBook Air 11" Early 2014 Logic Board Replacement.
I see a lot of dust I can’t tell if after fixing the damage if your system will work here. Using it in this state will be very difficult as your systems SMC logic lost connections it needs to monitor things. So at this point SMC will put your system into CPU Safe Mode if its even able to startup. The CPU’s clocking will be dropped to a very low clocking and the fan will ramp up to try to keep the system from overheating.
If you are not planning on saving the system then I would recommend just getting this case to hold your SSD so you can salvage your files OWC Envoy Pr'''o''' Portable, Bus-Powered USB 3.0 Storage Enclosure for select Apple Flash SSDs from most 2013 to 2015 Mac Models
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
John será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 46
