Ir para o conteúdo principal
Dell Inspiron 1420 14.1" laptop, released in June 2008. Identified as the 1420 on the bezel above the keyboard, available in 8 different colors.
20 Perguntas Visualizar todos
How do I access the battery charger connector?
The battery on my 1420 does not charge. I have bought brand new charger and it still will not charge. The battery seems to be OK because I was able to use the laptop until the charge ran out.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi, Here is a link to allow you to download the service manual for your computer. The troubleshooting section should help you find the answer you need. Good luck.
http://support.dell.com/support/edocs/sy...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
jes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,456
