Will I lose True Tone if I replaced the Front Camera and Sensor Cable?
iFixit Guide: iPhone 8 Plus Front Camera and Sensor Cable Replacement
Esta é uma boa pergunta?
No, You will lose True tone if you Change the Screen.
Esta resposta foi útil?
If you're Changing your Screen you will need to reprogram your Screen to your iPhone 8
This is not the correct answer, after changing the sensors true tone does not work
The marked answer is not correct, after changing the sensors true tone does not work!
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 246
1 comentário
Yes bro its will be lose,True tone is connected to the light sensor also
por yones rasti
