Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Perguntas Visualizar todos
Why is my display flickering?
My MacBook Pro 2017 with Retina Display is flickering since morning. The top part of the display is still good, but under this good part, the display is flickering and showing double visions. I restarted the Mac, I deleted the Cache, I updated and I tried to run it in safe mode. Nothing changed. Thank you for helping me, I am a poor student and I can't afford expensive repairs.
Greetings Felix
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Felix,
Aua - das sieht nach einer defekten GPU aus :-(
Du kannst ja mal beim Apple Support anfragen ob es da noch Support dafür gibt. Oder Du schaust ob es von Apple eine Rückrufaktion gibt. Die hier hat zwar etwas mit der Hintergrundbeleuchtung von deinem Gerät zu tun, könnte aber vielleicht helfen: https://support.apple.com/de-de/13-inch-...
Gruß vom Ben
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Felix Enderle será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 58
