Ir para o conteúdo principal
O iPad Pro de 11" de segunda geração foi lançado em março de 2020 com os números de modelo A2228, A2068, A2230 e A2231.
iPad won't turn on
iPad Pro 11’ won’t turn on. The port is clean. It won’t turn on despite being fully charged. Unable to read diagnostics.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
hello Bernie,
it's been a while and you probably have done it by now. Maybe it will be useful to someone. Unable to read diagnostics because it does not start. If you look at the closer you will find that it is drawing approximately 200mA when you press the power button. This is a problem to be solved in a good repair shop. Probably the damage was due to a defective cable or charger. Similar damage may occur with excessive wear of the charging port (usb-c in this model).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bernie Wolter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 421
