Ir para o conteúdo principal
Samsung's flagship tablet, released in March 2017. Identified by model number SM-T820.
Gets stuck in booting up and doesn't progress from there
My Samsung Galaxy tab s3 (model#SM-T820) seems to charge normally. When starting up it gets stuck in the booting up cycle and the icon just spins. The system will advance no further. This is a hand me down so there is no data to save. At this point I can see 3 options: resetting the whole system, using it as a paper weight, or using it as a target the next time I go shooting. Any and all ideas will be GRATEFULLY accepted.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @oldguy52 ,
With no data loss to worry about, try a hard reset using the hardware keys.
If that is no good try reflashing the ROM with Odin and check if that works.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Pete Nelson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 109
