Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
Microphone problem after screen replacement
Hello.
When I replace the display with a new LCD, then I screw the tape with (speaker-microphone-face id etc), while recording the front camera I hear a slight squeaking in the background. But when the tape is on the outside of the screen, it is all ok. Is it maybe some kind of lack of grounding in the screen? Is there any method to change it? (in the original display everything is fine) Any suggestions or help are welcome.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Yes, I checked everything. This little golden clip does not eliminate the problem. Flex is ok, everything works fine on the original screen.
por
Adicionar um comentário
3 respostas
Did you place back the little gold grounding clip as can be seen in step 22 of this guide? Substituição da tela do iPhone X
Also double check the flex cables to ensure they are not damaged.
Esta resposta foi útil?
Pontuação 0
1 comentário:
por
I have 350 of the same replacement displays, I checked 30+ lcd's and they all have the same problem. (little noise - “piiiiii” when i recording front camera)
Pontuação 0
This is an issue with bad quality replacement frames. Sometimes it is easier to use a good quality screen to save the hassle.
Pontuação 0
2 comentários:
So you are saying that in my replacement displays, weak aluminum or other metal was used during production, which interferes incorrectly with the phone casing?
por
Adicionar a sua resposta
Lucas Szeyk será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 390
