Cant boot, how do I make a backup?
Few problems. Some updates was happening, but something went wrong. Now, after typing in my password its trying to load for some time, eventually ending up with a black screen with a white circle and a line (like a forbidden sign). So I cant boot up.
I have tried these steps :
- Tried booting up on a external Mac test disc with catalina. I can see my internal SSD, but theres the normal one called MacHD that seems completely empty? Then theres also another partition/drive called Data, which seems to have some wierd files.
- When i try to use First Aid on MacHD, nothing happens. But when i try and use First Aid on the Data disc, it seems encrypted and asks for a code i dont remember (its not the same code as i use to login with)
- Is my SSD broken?
I’ve tried searching google for a Macbook Air 1466 SSD adapter to sata or USB. I can find one that pops up, but that shows it only works for the 1466 (2012) version, say what?
Update (02/18/2021)
@danj Last 3 questions :
- Where can I read that my A1466 (2017) SSD is compatible/the same as the 2015 SSD you mentioned earlier?
- If i get the adapter to work, is it even possible to copy over data from an encrypted SSD
- Is it possible to do a clean MacOS installation on a encrypted SSD ?
Esta é uma boa pergunta?
1 comentário
Here's a listing which should help explain why I know your SSD is the same as the 2015 system MacBookAir7,2
As you can see all of these are using the same interface and If you review this great guide here The Ultimate Guide to Apple’s Proprietary SSDs under the Generation 4 section.
So I'm very sure the OWC case will work, and besides I've used it a few times to save a customers data from a dead system,
As for copying off encrypted data a file which is encrypted will stay encrypted! You would need to know the password to unlock the file.
If your drive is encrypted then its a question on which way you encrypted it. If you used FileVault2 you should have saved the FileVault recovery key to unlock the drive. Otherwise you'll need to speak with the application maker who's encryption you used.
Formatting the SSD will loose all of the data on it! If that is your intent then you should do a secure erase. Newer macOS releases hide this as its assumed you have encrypted the drive Secure-erasing your Mac’s disks is no longer secure, Apple says to make sure the data is not recoverable! But don't you want to save the data?
por Dan
