Ir para o conteúdo principal
iPhone 6 loud speaker not working after repair
Hi there, so I repaired my iPhone 6 recently, and now the speaker isn't working. It was working whilst I was testing it and then suddenly it cut out, and after trying different speakers and lightning connector flexes it still doesn't work. What should I do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The likely problem is with the lightning connector that is next to the battery connector as seen in step 20 in these instructions:
iPhone 6 Speaker Replacement
Try disconnecting the connector and clear it of any debris. After this, carefully reconnect the connector and see if that restores the loud speaker to working.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Adrian Wrona será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 62
