Ir para o conteúdo principal
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
20 Perguntas Visualizar todos
Is my LCD toast? Green lines at bottom
I am trying to repair my cracked screen on iWatch series 4.
The screen was working prior to repair, it was cracked around the edges. I started removing glass. Now the screen is not working . It had green lines at the bottom. I'm assuming one of the edge cables is broken . Can I fix it or is my LCD toast.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sorry you’ll need a new display assembly Apple Watch Series 4 Screens
Esta resposta foi útil?
Pontuação 2
4 comentários:
There is no Micro repair method ?
por
@sendo - Sadly no, its part replacement time.
por
Thanks Dan. First attempt at fixing iwatch . Second attempt cut to deep and collected the polariser on S2. 3rd , 4th and 5th attempt successful. Live and learn. Thanks Dan.
por
Yes it does take a bit of skill, happy in the end you got it working again! - Don't forget to accept the answer
por
Adicionar a sua resposta
Peter Senden será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 289
